Im looking for a graphics card and these are my current options that fit my budget
1.http://www.tigerdirect.ca/applications/searchtools/item-details.asp?EdpNo=5639258&pagenumber=1&RSort=1&csid=ITD&recordsPerPage=5&body=#ReviewStart
2.http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=6723849&CatId=2306
Which one would be better for gaming?
For example if i were to be playing modern warfare 2 on highest settings or crysis warhead, what would be the fps for both of the cards?
And would these cards work with this pc?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00714131&lc=en&cc=us&product=3199120&dlc=en
I realized the hd5570 is 1gig vid memory and the 9800gt is 512mb...is that a big difference?
Lastly, is there a better graphics card under 100$ that Is better than these? If there is please fill me in.
Thanks a ton in advance,
Matt
Matt
