I have a brand new self built computer that will not run stable during the initial boot into Bios. It freezes when it loads into the initial BIOS screen and other times it will continuously restart when it attempts to load the BIOS screen.
The computer has never ran stable yet. I have read through your previous post about what to check for before posting a new thread.
So this is a new build for a friend of mine. Here is a list of the parts I am using to create the machine:
Cooler Master CM 690 Advanced II Case
GIGABYTE 790 FXTA-UD5 Motherboard
ThermalTake TR2 RX 1200W PSU
AMD 1090T Processor
Cooler Master V8 Heatsink
G Skill Ripjaws DDR3 240-pin 8GB (4gb x 2) 1600 MHz ( PC3-12800 ) Memory
Kingston Solid State Hard Drive 128gb
Radeon 4970 X2 Video Card PCI-E - 1
Radeon 4970 X2 Video Card PCI-E - 2 (Just so your all aware, I attempted to run without both video cards connected and the same issue exists)
KILLER 2100 Network Card
LITEON 24X DVD-RW Sata Drive
Cables Unlimitied 3.5" Memory Card Reader
So I built the entire machine and followed every step in the Motherboard manual. All the connections are legit, they have been checked about 10 times. Initially I had all the parts listed above installed and I tried to turn on the machine. The first thing I noticed was the fluctuation in power on all the parts.Silent at first then vvvrrrrRRROOOOMMMmmmm Up and down up and down then stable. THen BEEEP. Nice basic loud beep but no video whatsoever.
So since I had no video I pulled out the KILLER 2100 Network Card to start testing parts. Turned power on and again Power Fluctuation Up and Down, Up and Down, Fast spin, slow spin, then quiet and stable and my basic BEEP. After the beep to my amazement I had VIDEO! Horay!. Then it loads the BIOS next, a big colorful Gigabyte Bios screen pops up and boom it crashes and restarts. It then proceeded to load the initial bios screen again but to no avail it still crashed and restarted upon loading the bios screen. So I pulled one of the video cards out and only ran one card. Upon turning it on the machine still did the weird power fluctuation and the same failure occurred when the bios screen loaded.
So I removed the 4870 and tried a different video card entirely (Geforce 460). Turned it on and no crazy power fluctuations this time, it loaded to the bios screen, and oddly enough it let me actually go into bios and look around. But upon exiting bios, boom, it crashed. (No i did not change any settings whatsoever while I was in BIOS).
After that failure I tried a different solid state hard drive (w/ geforce 460), I took out the Kingston and put in a Super Talent 64gb, No power fluctuation, but Bios still crashes and I'd like to mention that sometimes it lets me into the real bios options and sometimes it does not. So after all that swapping and changing of parts I took out one of the RAM Sticks. Turns on and a super long beep goes off. No bios No nothing. So after that I put my other stick back in and I currently have it down to the CPU, RAM, VIDEO CARD and a HDD only. Those are literally the only parts connected and it still fails. I don't know what the issue is except the memory, and here is why I believe that is the issue.
When i Installed the geforce 460 and it let me go into the actual Bios Screen I was inside the DRAM Timing Information and it showed the speed of the Memory. I was just sitting there staring at all the options and I saw the Memory Speed change back and forth, very rapidly from 400Mhz to 800Mhz in an extremely glitchy fashion, you could tell what it was doing was not normal. Reminded me of when nintendo games would fail, Big Blocks on the numbers and what not. Glitchy for sure.
Something else worth mentioning: When it freezes and you hold in the power button to shut it off, all the lights inside the case on the various equipment fade off, not shut off instantly.
Questions we need answered:
So my first question is why does the bios freeze and fail?
Second question is what are the power fluctuations all about when I have the 4870s installed (Having one 4870 installed also causes power fluctuations)?
and finally the other question is "Would in-compatible RAM make these issues im having exist in a new build?"
I'm in your hands now, I really don't know where to go from here to be honest with you guys. I have 14 years experience with computers. An associates degree in Computer Science and I have built a few PCs for friends in the past with no issue. I will be forever grateful if I could have some help on this. You can be as technical as you like with your responses and I will be able to decipher what you mean and try out your methods.
Thank you.
Ryan
AMD 1090T Processor
Thank you.
Ryan
