Help with q9300 temperature!!
hi everyone
I need some help with my intel core q9300 temperature
i think my cores temp are too high or what do you think ??
SpeedFan 4.43
http://img607.imageshack.us/f/cpul.png/
CPUID HWMonitorPro
http://img861.imageshack.us/f/cpu2.png/
and i have this case
www.nzxt.com/new/products/crafted_series/lexa_s
and this i my psu
www.itwinkle.com/hp46posu51.html
1 answer Last reply
More about help q9300 temperature
  1. The max temp I see in your screen shots is 58C, if your are running under full load (I use Prime95) then this temp is fine. In fact, it's fairly low, you can run 70--75C without issues.
    If it is an Idle CPU temp, ah, then its pretty high.....
    What CPU cooler do you have stock or aftermarket? (this will have the largest effect on CPU temps...)
    Are you running stock speeds or are you OC'ing?
CPUs Core Temperature Intel
