I recently bought a Rosewill RC-404 gigabit network card, regular PCI, to throw in my old Pentium 4 machine that I'm using as a file server. However, when I install the card, I'm unable to power up the computer. The power supply LED blinks, and the power supply makes a clicking noise, but the fans don't even spin up.
I previously had a (working) 10/100 network card in the PCI slot that I'm trying to use, so I know the PCI slot functions properly. I was able to put the old card back in and the computer booted back up and the old network card worked fine again.
Now, I realize I bought a cheapo network card, and most would be quick to blame it and tell me to get a better card. However, I put the card in my AMD 1090T machine and it worked fine and provided a network connection without a problem, so it seems the card isn't defective.
The power consumption can't be significantly higher than the old NIC I'm replacing, so I doubt it's an issue of overloading the power supply. The computer has an old Intel Desktop Board with the 915G express chipset. There are two standard PCI slots, a single PCI Express x16 slot, and an x1 slot, and NONE of the other slots have anything in them. I'm using on-board graphics and since it's a server I didn't even bother with audio drivers.
I'm stumped. Anyone have any insight?
