Solved
PC suddenly won't start (motherboard problem?)
Last response: in Systems
Hello,
I built my PC about a month or so again, and after some initial PSU problems, it's been working perfectly. However, after installing a network card two days ago, things started to go wrong. It shut off once, randomly, that night, and twice yesterday before it completely failed altogether.
The first time it shut down yesterday, I removed the network card, but that didn't fix the problem. The PSU also passes the paperclip test (although I realize that has limitations), so I've been assuming the problem to be with the mobo.
Also, there don't seem to be any loose connections, and nothing seems to be touching the motherboard itself. Is my mobo shot, or does anyone have any ideas?
Asus Sabertooth 55i motherboard
ADATA 2x2GB RAM
Intel i7 870
Radeon HD 5850
Thanks,
Homebuilt system Expert
It wont start at all? Nothing spins, no lights?? What was the previous issue with the PSU, did it just die, or did it pop? What is the current PSU make, model and watts?
Homebuilt system Master
Motherboard Master
Work systematically through our standard checklist and troubleshooting thread:
http://www.tomshardware.com/forum/261145-31-read-postin...
I mean work through, not just read over it. We spent a lot of time on this. It should find most of the problems.
If not, continue.
I have tested the following beep patterns on Gigabyte, eVGA, and ECS motherboards. Other BIOS' may be different, but they all use a single short beep for a successful POST.
Breadboard - that will help isolate any kind of case problem you might have.
http://www.tomshardware.com/forum/262730-31-breadboardi...
Breadboard with just motherboard, CPU & HSF, case speaker, and PSU.
Make sure you plug the CPU power cable in. The system will not boot without it.
I always breadboard a new build. It takes only a few minutes, and you know you are putting good parts in the case once you are finished.
You can turn on the PC by momentarily shorting the two pins that the case power switch goes to. You should hear a series of long, single beeps indicating memory problems. Silence indicates a problem with (in most likely order) the PSU, motherboard, or CPU. Remember, at this time, you do not have a graphics card installed so the load on your PSU will be reduced.
If no beeps:
Running fans and drives and motherboard LED's do not necessarily indicate a good PSU. In the absence of a single short beep, they also do not indicate that the system is booting.
At this point, you can sort of check the PSU. Try to borrow a known good PSU of around 550 - 600 watts. That will power just about any system with a single GPU. If you cannot do that, use a DMM to measure the voltages. Measure between the colored wires and either chassis ground or the black wires. Yellow wires should be 12 volts. Red wires: +5 volts, orange wires: +3.3 volts, blue wire : -12 volts, violet wire: 5 volts always on. Tolerances are +/- 5% except for the -12 volts which is +/- 10%.
The gray wire is really important. It should go from 0 to +5 volts when you turn the PSU on with the case switch. CPU needs this signal to boot.
You can turn on the PSU by completely disconnecting the PSU and using a paperclip or jumper wire to short the green wire to one of the neighboring black wires.
http://www.youtube.com/watch?v=5FWXgQSokF4&feature=yout...
A way that might be easier is to use the main power plug. Working from the back of the plug where the wires come out, use a bare paperclip to short between the green wire and one of the neighboring black wires. That will do the same thing with an installed PSU. It is also an easy way to bypass a questionable case power switch.
This checks the PSU under no load conditions, so it is not completely reliable. But if it can not pass this, it is dead. Then repeat the checks with the PSU plugged into the computer to put a load on the PSU.
If the system beeps:
If it looks like the PSU is good, install a memory stick. Boot. Beep pattern should change to one long and several short beeps indicating a missing graphics card.
Silence, long single beeps, or series of short beeps indicate a problem with the memory. If you get short beeps verify that the memory is in the appropriate motherboard slots.
Insert the video card and connect any necessary PCIe power connectors. Boot. At this point, the system should POST successfully (a single short beep). Notice that you do not need keyboard, mouse, monitor, or drives to successfully POST.
At this point, if the system doesn't work, it's either the video card or an inadequate PSU. Or rarely - the motherboard's PCIe interface.
Now start connecting the rest of the devices starting with the monitor, then keyboard and mouse, then the rest of the devices, testing after each step. It's possible that you can pass the POST with a defective video card. The POST routines can only check the video interface. It cannot check the internal parts of the video card.
Oops, forgot to list the PSU up there with the other parts. It's a Corsair 750TX.
The last PSU (also a Corsair 750TX) was DOA. All the fans started for about a quarter of a second before everything shut off. Actually, it was very similar to the problem I'm having now, except that now even the fans only start occasionally, while working fine with the paperclip test.
That said, I've worked through the checklist multiple times, and it's nothing under there. It won't POST, either, so I suppose I should try to get a hold of a known good PSU before sending in my motherboard. It seems odd to me that a practically brand new (and previously good) PSU would fail overnight, but I'm no expert, either, so I really have no idea.
Related ressources
Best solution
I know you have worked the checklist, but you're sure front panel connections are right? ALL connections are really tightly plugged in? If that is all good, I'm with you. Get a working PSU and see if it fires up
Is cpu set correctly, did you double check that?
The front panel connections are fine, yeah. It's one of the first things I checked. The mobo has a power button of its own, too, which does the exact same thing.
So yeah, I'll look around and see if someone around has a spare PSU to borrow. Thanks!
Ask the community
