I'm kind of a noob when it comes to PC sound systems so I don't know exactly what I need. I was using a Klipsch Promedia 2.1 system but the sub went dead so I've decided to upgrade. I purchased an X-Fi fatal1ty soundcard and I'm considering something like this Polk audio subwoofer http://www.newegg.com/Product/Product.aspx?Item=N82E16882290034&cm_re=subwoofer-_-82-290-034-_-Product.
I know that sub is for a Home Theater system but I thought I could get it to work on my PC using the new soundcard with the old Klipsch speakers. I bought a 'trial version' at Best Buy to test out but I don't know how to hook things up right. I was using the analog input in the soundcard which works for the sub, but then apparently I have no way to have regular speakers as well.
So my questions are, is it possible to use a home theater sub like this in my PC and what will it take to get it working? Will I be able to still use my Klipsch Promedia speakers? Any other suggestions on what I should buy instead?
