ASRock Extreme3 Gen3, new build problem
December 16, 2011 2:37:58 PM
Parts:
MB: Z68 Extreme3 Gen3
MEM: Corsair Vengeance 2 x 4GB (tested and working)
PSU: Corsair TX 850W
CPU: i5 2500K
GPU: GTX 580
Everything works, but:
If one or two of the memory modules are placed in either slot DDR3_A1 and/or DDR3_A2 I get error code 38 which is Post-Memmory North Bridge initialization:
Only when memory modules reside in either slot DDR3_B1 and/or DDR3_B2 it boots ok with no error messages and everything in BIOS looks right.
Same exact problem as this guy: http://forums.tweaktown.com/asrock/4...tml#post407347
and this guy: http://www.tomshardware.co.uk/forum/...12-boot-sticks
and this guy: http://forums.whirlpool.net.au/archive/1684199
and this guy: http://www.eggxpert.com/forums/thread/742584.aspx
Anyone have a clue what's going on?
December 16, 2011 6:08:42 PM
Have Asrock possibly printed wrong labels on the memory slots (confused the numbering)? Which ones are supposed to be populated first according to the user manual? If you have a chance, borow two more DDR3 strips from a friend and populate all slots. See what happens. If the RAM is then fully recognized and the system boots - it would confirm my idea above... If not, well, that would be a hint that the A-group of slots may be faulty. In that case I'd rma the board. Or check if there is a BIOS update that might sort the problem.
December 17, 2011 5:22:34 AM
It works now:
I removed the CPU, inspected the socket pins for dust or damage/angles, they all looked like they should, I reseated the CPU, and it works now. I have no idea why that fixed it.
Since the thermal compound was brand new air bubbles shouldn't be that much of a problem right? I didn't remove or reapply any of it. The temperatures are great exactly as they were before. 34C.
December 17, 2011 9:07:35 AM
Was the CPU cooler really completely down on all four mounting points? Unless the CPU itself was not properly lined up inside the socket I can only imagine unevenly applied pressure to be a reason for that...
Coming to the thermal compound - I'd strongly recommend to be very careful about not redoing it. At least do yourself a favour and thoroughly stress-test while you're closely monitoring the temperature
Anyway, glad to see that you were able to sort it out by an easy and inexpensive solution.
cheers!
