Sign-in / Sign-up
Need Advice on First Build
  • New Build
  • Systems
  • Product
Last response: in Systems
January 15, 2011 9:27:40 PM
Approximate Purchase Date: Next month-ish or so.
Budget Range: 1000-1200
System Usage from Most to Least Important: Gaming (COD games, Starcraft 2 and much more on high settings), video editing (After Effects CS5 and Sony Vegas 10), usual web browsing/chatting, and photoshopping (Adobe Photoshop).
Parts Not Required: Keyboard and mouse.
Preferred Website(s) for Parts: Newegg.com and Microcenter.com
Country of Origin: California, United States
Parts Preferences: Nice resolution and crisp monitor and an Antec Nine Hundred.
Overclocking: Maybe
SLI or Crossfire: Maybe
Monitor Resolution: 1920x1080
Additional Comments: I would like a not so loud computer and run without lag. Can you please find a monitor is clear and crisp? I also prefer 12GB of RAM if you know any good deals.
LIST
ASUS DRW-24B1ST/BLK/B/AS (2x)
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
PowerColor AX5770 1GBD5-H Radeon HD 5770 1GB 128-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card
[Combo] Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K/CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
[Combo]GIGABYTE GA-P67A-UD3 LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard/Patriot Gamer 2 Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model PGD38G1600ELK
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
Grand TOTAL: $910.62 (With CA Tax and shipping)
More about : advice build
January 16, 2011 11:17:37 AM
I like the Antec 900 case, but unmodded, the cable management is pretty rudimentary. And it does not come with a case (system) speaker.
Because this is your first build, look at the following threads while you are waiting for your parts.
Build it yourself:
http://www.tomshardware.co.uk/forum/274745-13-step-step...
And although this primarily a troubleshooting thread, the first part contains a checklist that will catch most noob mistakes:
http://www.tomshardware.com/forum/261145-31-read-postin...
m
l
January 16, 2011 12:29:26 PM
One thing I noticed right away, the 5770 is not a good choice for 1920x1080. I would get at least a 6850 or a gtx 460 1gb.
m
l
January 16, 2011 12:32:18 PM
+1 on the Antec 900. adding to what 'jsc' said-> i like the 900 too... but that one is an older model and is missing 'current-tech' stuff such as: no front fan filters (something they fixed in the 900 II), interior isn't black, no front USB3, no 2.5" bay for ssd's, etc...
you can get a much better video card -> try something like this for ~$1200:
- ASUS Black 24X DVDRW: $17
- SAMSUNG Spinpoint F3 1TB: $70
- Windows 7 Home Premium 64bit: $100
- Acer G235HAbd 23'' 5ms 1920x1080 WideScreen LCD: $147
- Antec DF-35 Black Computer Case: $115 ($100 after mir)
- Intel Core i5-2500K + CORSAIR CMPSU-650TX PSU: $300 ($280 after mir)
- GIGABYTE P67A-UD3 SATA6 USB3 + Patriot 8GB (2x4GB) DDR3 1600: $205
- HIS Radeon HD 6850 1GB: $180 ($165 after mir)
TOTAL: $1134 ($1084 after mir)
m
l
January 16, 2011 3:55:13 PM
Thanks Mike, since the total went up a little. I decided it won't hurt going to i7. Can you please give me an i7 2600K SB build list? Thanks. -David
m
l
January 16, 2011 4:56:10 PM
you can use the exact same build... just swap the i5-2500K with the i7-2600K
everything else can stay exactly the same
m
l
January 16, 2011 5:41:00 PM
I like wasupmike's build but, I would swap .....
MoBo - $495 - ASUS P8P67 Pro http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
CPU - incl above - Intel Core i5-2600K http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Spinpoint F3 1TB is now $55 w/ promo code BTW
I'd get an LED monitor insread of older CCFL lit designs
Monitor - $180 - ASUS VE247H 23.6" LED http://www.newegg.com/Product/Product.aspx?Item=N82E168...
And I'd take this 460 or 470 over the 6850 ...
This superclocked 460 1GB is $5 cheaper than the 6850, has lifetime guarantee and comes with free Just Cause 2 game ($40 on amazon) .... or a net cost of only $120
This 470 is $220 and comes w/a free Mafia 2 Game Coupon ($35 on amazon)
GFX - $220 - ASUS ENGTX470/2DI/1280MD5 GeForce GTX 470 http://www.newegg.com/Product/Product.aspx?Item=N82E168...
The 650 TX is fine for a single 460 or 470 GTX but it's not certified for twin 460's or 470's.
This $69 Antec is certified for twin 460's.
This XFX Black Editioin 850 gets a 10.0 performance rating on jonnyguru and can handle twin 470's
m
l
