Will these parts work together?
Ok guys building a new system for a friend and wanna know if these parts will work nicely with each other.
RAIDMAX SMILODON Extreme Black ATX-612WEB 1.0mm SECC Steel ATX Mid Tower Foldout MB Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811156078
Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148433
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
GIGABYTE GA-P67A-UD4 LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128463
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) 4 x 256KB L2 Cache 6MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
hec X-Power Pro 600 600W Continuous @ 40°C ATX12V V2.2 SLI Ready CrossFire Ready Power Supply
and
ASUS ENGTX470/2DI/1280MD5/V2 GeForce GTX 470 (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.578355
Thanks in advance
3 answers Last reply
More about will parts work together
  1. Could you post their names, so we don't have to go and click on five different links, please? Thank you!
  2. Shouldn't have any compatibility issues.
    If you are looking for suggestions you will have to post what the computer is mainly used for and also a budget.
  3. Computer will be used mostly for WoW, Starcraft 2, and L4D2. Possibly will be used to play other games coming out.
New Build Systems Product
