So, I spilled water on my laptop, rinsed it out and all that, let it dry for 4 months, and then i tried to power it back on.
The LCD screen does not turn on, I have plugged it into an external monitor and it works, it can boot into windows fine, but the bios screen is made up of dollar signs ($), I cannot access the bios settings at all and it only happens in the bios. The laptop is a Dell XPS M-1210, and the external monitor works fine with it, but I cannot get the LCD to work or the dollar signs to go away.
Thank you for any help you can provide,
- Daus
- Daus
