Solved
Memory Timings or Speed?
Don' know what to sacrifice. Been looking at these two products.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231460
DDR3 1866 (PC3 14900)
9-10-9-28
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231402
DDR3 1333 (PC3 10666)
7-7-7-21
Will be using this system mostly for gaming, but what would the timing speed increase and vice versa.
Thank you in advance.
5 answers Last reply Best Answer
More about memory timings speed
  1. Anyone help please.
  2. Best answer
    neither of the two you listed - get this instead:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231461
    Good blend of both plus 20% off with promo code.
  3. Ok thank you so much.
  4. No problem, good luck with your build.
  5. Best answer selected by loudwhisper.
Memory DDR3 Products Product
