Hey Guys,
Just upgraded my gaming rig and have some leftover components and figured I’d build a HTPC/PVR for the living room.
These are the components I have to use:
Intel Core 2 Duo E8400 Wolfdale
ASUS P5Q
OCZ DDR2 PC2-6400 REAPER HPC 4GB EDITION
ASUS EAH4850/HTDI/512M
Cool Master Hyper 212 Plus
Plan on buying the following to finish up the build...
A couple of SAMSUNG Spinpoint MP4 HM640JJ 640GB 7200 RPM
SAMSUNG Black 12X BD-ROM
SILVERSTONE ST45SF 450W
Can someone recommend a decent TV Tuner card and PVR software. My wife will get the most use out of this rig so will likely end up being a Win 7 box as she's not too Linux friendly.
Any and all advice will be greatly appreciated. Would you advise upgrading the cpu/mobo or will this be sufficient?
Thanks
RC
ASUS P5Q
Thanks
RC
