Hello, I have a acer aspire ax1301-b1702 with a measly 220w psu, I do have a power supply lieing around but it definatly wont fit in the case, could i just have the power supply outside the case sitting on something with all the cables plugged in?
If you must feel you need to run the power supply outside of the case you must keep a solid ground between the case and the power supply. If you don't keep a good solid ground you may cause problems down the line.
I think he meant electrical ground, since a PSU (which is grounded) is usually in contact with the case, any charge build up inside the case will go out through the PSU. If you don't ground your case it might build up a strong enough charge to damage your components.
