G
Guest
Guest
Hi,
This is my first post so let me know if it's not clear enough.
I am planning on building a new system (for the first time in many years). I mainly use it for Gaming, Software Dev, Multimedia storage. I have read alot of reviews etc and have came up with what i think is a relatively good build for my needs. But i don't have much experience when it comes to hardware so i'd like your opinions / suggestions on what i need.
Any help / advise would be great!
Thanks
Motherboard (asus has never let me down)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131682&cm_re=p8p67_pro-_-13-131-682-_-Product
CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072&cm_re=i5_2500k-_-19-115-072-_-Product
CPU Cooler (apparently it fits 1155)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181010&cm_re=h50-_-35-181-010-_-Product
RAM (i've read ALOT of good reviews about G.Skill but i'm not sure whether i should go for 4GB or 8GB and whether timings will be important for my needs. i'd like something that i wouldn't have to upgrade for a while)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231427
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231430&Tpk=F3-12800CL7D-4GBXM
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428&Tpk=F3-12800CL9D-8GBXL
Graphics Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125333
Primary HDD (i know i'm missing a trick by not getting an SSD but i figure that could be an upgrade when/if SSD's get cheaper)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533&cm_re=WD1002FAEX-_-22-136-533-_-Product
Secondary HDD
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136534&cm_re=WD10EALS-_-22-136-534-_-Product
Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042&cm_re=antec_300-_-11-129-042-_-Product
PSU (not sure about this PSU as i don't want to skimp but dont want to spend a fortune ... this seems to be a middle ground)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371021&cm_re=antec_truepower_new-_-17-371-021-_-Product
Thanks
CPU
or
or
Graphics Card
Secondary HDD
Case
