Hi,
I work for a major research university in the US, where we have a 3 projector visualization wall used for virtual reality research. We are putting together a new build to run the setup and I would like some input on whether the parts we have chosen will work well together. Most of our applications are custom written opengl apps and are single threaded. I would love to wait for the high end sandy bridges to come out in Q4, but we need to buy as soon as possible. I don't really have a budget, but I am trying to be at least slightly reasonable. We have a tendency to buy top of the line and wait several years before replacing.
Here is what we have so far:
Intel Core i7-2600K Sandy Bridge (for our single threaded apps this looks like it has better performance than the i7-980x)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070
ASUS P8P67 WS Revolution
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131694
2 x G.SKILL Ripjaws X Series 8GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231431
Antec High Current Pro HCP-1200 1200W (probably overkill but we want the option of potentially extending to tri or quad sli)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371043
2x Western Digital VelociRaptor WD6000HLHX 600GB 10000 RPM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136555
COOLER MASTER Hyper 212 Heatsink (Will this run into the ripjaws ram?)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
Arctic Silver 5 Thermal Compound
http://www.newegg.com/Product/Product.aspx?Item=N82E16835100008
COOLER MASTER HAF X Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225
LG WH10LS30 10X Blu-ray Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136181
Logitech MX 5500 Revolution Black Bluetooth Cordless Desktop Standard keyboard & Mouse Kit
http://www.newegg.com/Product/Product.aspx?Item=N82E16823126038
For graphics we are deciding between the Nvidia Quadro Plex 7000
http://www.nvidia.com/object/product-quadroplex-7000-us.html
or 2x Nvidia Quadro 6000 in SLI
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133347
Will these work together? Any better options?
Thanks,
-Bret
Thanks,
-Bret
