Solved
120MM fans for my NZXT Phantom Case
  • New Build
  • Cases
  • Fan
  • Fan Controller
  • Systems
Last response: in Systems
January 19, 2011 3:01:55 AM
So as the headings states, I am not sure if this fan will blowout the manual fan control that is built into my Phantom Case.
This is a hardcore fan, and I am receiving my new build in mid Feb. I am not too concerned with how loud it is, just that it won't overload my fan control and break something.
Anyway, I would love to hear some feedback.
P.S. I want this fan in particular because no other fan can create that amount of CFM, not that it is completely necessary :)
More about : 120mm fans nzxt phantom case
Best solution
January 19, 2011 3:35:19 AM
^ I doubt it would, the Fan controllers are rated 20W, whereas for that Delta it would need an input power of about 29.4W, so either it might not be able to power it fully or even bad might die trying :p , I can be wrong though,...
January 19, 2011 5:05:41 AM
Then what would I need to control it?
m
l
January 19, 2011 5:16:38 AM
^ You should search for a fan controller which can handle atleast 30W min,...
Read its customer reviews, would give better idea,...
m
l
January 24, 2011 11:31:58 PM
Best answer selected by brohde88.
m
l
