Ok, so I'm having a massive problem setting up my 3 monitors with my new 6870. I currently have 2 25" hanns G monitos running 1920 x 1080 and then I have one 24" samsung that runs 1920 x 1200.
The connections ont he 6870 are 2x DVI, 2x miniDisplayport, 1x HDMI
The Hanns G monitors have 1x DVI and 1x VGA on each
The Samsung has 1x DVI, 1x HDMI and 1x VGA
Currently they are connected by DVI-DVI to the 1st, DVI-HDMI to the 2nd, and miniDis-DVI for the third. Which is as far as I read the way to set them up
I currently get told I must disable one of the monitors when I try to activate the third.
Ideally I want the samsung in the middle and 2 Hanns either side.
Please can someone tell me why they won't work or if I'm doing something wrong. I've had this problem for weeks and I cant seem to get an answer.
