Weard problem with Linksys WRT54GL wifi-router
Hello,
I'm really in trouble and was hoping some of you can help me here :??:
Problem is that through wifi-connection it can't find our internal server "server-x". Another internal server and all other things are working (internet, e-mail etc.)
But with LAN-cable it shows "server-x" with no problem.
It seems that it is DNS issue, because using wifi, "server-x" ip-address is pingable.
Router configuration is static ip. DNS addresses entered are the same that "ipconfig /all" showed with
LAN-cable.
What could be the problem. I have really no clue what to do :(
Thanks in advance...
2 answers Last reply
More about weard problem linksys wrt54gl wifi router
  1. What OS?
    On your computer have you tried to delete the wireless profile and then connect to the router again?
  2. Windows 7 and XP
    Have tried what you suggested but with no result :(
Configuration WiFi Servers Wireless Networking
