Welcoming any advice or suggestion on improving my rig. Thanks!
Approximate Purchase Date: Within a month
Budget Range: USD 1300~150
System Usage from Most to Least Important: Gaming, Web browsing, Presentations, Photoshop, Homework etc.
Parts Not Required: keyboard, mouse, monitor, speaker and OS. Already got Windows 7 64bit.
Preferred Website(s) for Parts: newegg.com or amazon.com
Country of Origin: Australia
Parts Preferences: Intel and Nvidia
Overclocking: Yes
SLI or Crossfire: No
Monitor Resolution: 1920x1080 minimum.
Additional Comments: Would be overclocking the intel i5-2500k to around 4.5 Ghz and probably going to overclock the GPU too, would greatly appreciate if you could gimme some advise on overclocking cause it's going to be my first time!
My current rig that I intend to build
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.575884
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
ASUS P8P67 PRO LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel ...
(Would an extra fan be advisable for the overclocking or would this be enough? thanks!)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231274
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-4GBRL
(Should I go for 8GB of RAM straight away? or would it be unnecessary?)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011&Tpk=corsair%20hx850
CORSAIR HX Series CMPSU-850HX 850W ATX12V 2.3 / EPS12V 2.91 80 PLUS SILVER Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197
COOLER MASTER HAF 922 RC-922M-KKN1-GP Black Steel + Plastic and Mesh Bezel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151188
SAMSUNG DVD Burner Black SATA Model SH-S223L LightScribe Support - OEM
GeForce GTX 570 (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
(There is so many brands selling this GPU, what's the difference? There is like Asus, Gigabyte, EVGA, Palit, with price differences. Please advise on which brand would be most suitable. Not willing to pay more for the overclocked one though. Thanks!)
That is my build so far, take a look and give me your thoughts! Thanks!
Overclocking: Yes
