Hello everyone,
I recently bought components to build my first tower on my own. Other than a few minor hiccups, and nothing happened like static from what I could tell, i was compulsive about grounding myself on the PSU. After testing it out for Fan operation I decided to hook it up to my monitor to hopefully work on installing Windows. So far almost every power-up has begun with a 2-second power-up, quick shut-down, followed by another power-up that stays powered on.
I can't get a signal to my monitor. I know my monitor works because I am using it on my older PC, but when I plug either the VGA cable or a DVI cable into my new comp's MB the monitor goes to sleep...
I have looked at multiple FAQs and guides regarding installation and normal troubleshooting solutions for this kind of problem but to no avail. One thing I have to fix when I get home is the Mount for the heatsink and fan, I turned the clips (or whatever they are called) the wrong direction... but I don't see how that would explain this problem...
Another concern I had was the SATA cables from the SSD HDD, and DVD drives being in the right ports, but I also don't think that would explain this problem...
The only other things I can think of are my video card not being in correctly, being in the wrong PCI slot, not being compatible with my MB, or I fried an important component at some point.
Please I have spent a lot of time trying to figure this out and would love some help. Also I tried taking out one and both RAM sticks...
Here are my components:
Mushkin Enhanced Chronos Deluxe MKNSSDCR120GB-DX 2.5" 120GB SATA III MLC Internal Solid State Drive (SSD)
Western Digital Caviar Black WD5002AALX 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Corsair Carbide Series 500R Black Steel structure with molded ABS plastic accent pieces ATX Mid Tower Computer Case
ASUS P8Z68-V PRO/GEN3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
XFX HD-695X-CNDC Radeon HD 6950 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 ...
CORSAIR XMS 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
HP 24X Multiformat DVD Burner Black SATA Model 1270i LightScribe Support
CORSAIR H100 (CWCH100) Extreme Performance Liquid CPU Cooler
CORSAIR Enthusiast Series TX750 V2 750W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power Supply
