Hello,
I am going to start from the beginning, so the text might be a bit longer, sorry for inconvenience
Recently I moved from one place to another, but I had very small car, so I basically packed my computer to a cardboard box and threw out the case. (It might be irrelevant, but I also removed motherboard battery for the duration of the journey)
On my new place, I installed it into an old case. Now the problem is that It doesn't want to start at all.
Hard drive doesn't even start spinning, nor the CPU or the Video card.
Not even power nor HDD leds. However the lighting on my motherboard still seems to be working. I cant do POST since I don't have a speaker. I have tried reseting BIOS, using a second PSU. The wiring seems to be ok(4pin cpu-, gpu-, main 24pin-, hdd wire).
My motherboard seems to be quite dead due to the transportation.
I am just asking if I have maybe missed something or is there anything else I can do.
Also my other guess is that the problems might be related to my CPU, would there be any way to check that?
One more thing, does it seem to matter if my motherboard is locked with 3 screws instead of 6?
Thank You in Advance
