Wireless connection
Hello,
I have been able to connect to my DSL router by pressing the wireless button everytime now it wont work my laptop i Siemans Amilo I have tryed fn& f2 button but still no joy when I try to get internet connection it says turn wierless on How can I fix this problem I think I need step by step instructions
1 answer Last reply
More about wireless connection
  1. First check your DSL router has DSL and Wireless light turned on , if yes......in your laptop open network connections through control panel to see the wireless conections around and you can also see if the wireless is turned off in your laptop..keep this open and then press Fn & f2 to check the changes.
LAN Wireless Connection Networking
