So I'm considering making sure my next build can easily be OC'd. I would like to be able to just run on a decent air cooler as I'm going for a budget OC. I'd like to start by saying that I'm currently considering the following to processors and would like some feedback:
AMD Phenom II X4 965 BE (currently $164)
Intel i5 i5-750 Lynnfield 2.66 (currently $200)
I understand from looking at benchmarks that the i5 is generally a stronger chip overall. My thoughts were that when overclocked, it might be possible that the Phenom would be better as AMD allows more fudge room for overclocking.
I understand some people always back one particular brand, but try to keep the fanboy stuff to yourself and stay objective. Does anyone know if my assumption that the 965 would surpass the i5 if both were overclocked is correct?
sidenote: One thing I feel I've noticed is that for AMD there isn't much of a mobo selection where as for intel it seems there are a lot more price options. For the AMD so far all i've looked at is: MSI 790FX-GD70 AM3 ($165) This may help bring the overall cost down if i can find an OC friendly board for less than 165.
