I am converting this desktop into a media center PC. I've already tested it, and it works perfectly - decodes full 1080p - even streams a full Blu-ray rip.
Below are the specs on the PC. It is currently in a mini-tower case. I am planning on getting an HTPC case, something like this one, which I think will work (let me know if it won't):
http://www.amazon.com/SilverStone-A...TDGQ/ref=sr_1_1?ie=UTF8&qid=1295537365&sr=8-1
The current PSU is very, very loud. I'd like to put something quiet in there when I make the move to the new case.
Thanks for the advice. Choosing a PSU always confuses me - too many different options, sizes, connectors, etc.
Specs:
HP a1747C (Athlon 64X2 4600)
CPU
AMD Athlon 64 X2 4600+ Windsor 2.4GHz 2 x 512KB L2 Cache Socket AM2 89W Dual-Core Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103751
Motherboard
Asus PASUS A8M2N-LA
http://h10025.www1.hp.com/ewfrf/wc/...&cc=ca&product=3356598&key=null&site=null#N52
Graphics Card
ASUS EAH4350 SILENT/DI/512MD2(LP) Radeon HD 4350 512MB 64-bit DDR2 PCI Express 2.0 x16 CrossFireX Support Low Profile Ready Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121310
Specs:
CPU
Motherboard
Asus PASUS A8M2N-LA
Graphics Card
