Temperature vs power consumption in graphic cards
  • Graphics Cards
  • Power Consumption
  • Temperature
  • Graphics
November 22, 2010 3:32:45 AM
Guys please see this link : -http://www.tomshardware.com/reviews/geforce-gts-450-gf1...
This link tells that power consumption of HD 5750 is lower than GTS 450 but temperature at load is quite high in comparison to GTS 450.
Now which things should be kept in mind while selecting the card when performance and cost is same.
High temp is more harmful or high power consumption in gaming system.
More about : temperature power consumption graphic cards
a c 217 U Graphics card
November 22, 2010 5:17:44 AM
Hi temperatures is realitive. For a human, we like 70-80F, but we also have to realize, other things like hotter temperatures, or at least, have no problems.
Video cards handle much higher temperatures than we do.
The 5750 under load only gets to 70-80C. That's perfectly normal. There is no harm in that.
It's quite possible, one of the reasons the 450 consumes more power, is that it's using power to cool the card.
I wouldn't be concerned about temps with either card, quite frankly. They both seem perfectly stable.
m
l
a b U Graphics card
November 22, 2010 5:53:44 AM
Frankly, I don't think either temp or power consumption is the ideal thing to look for . . . although power consumption probably comes closest.
Temps depend in part to the fan profile used, and the efficiency of the gpu's heatsink. So the temp of Card_A could be lower than Card_B, but B might throw off more heat . . . maybe into your case . . . maybe not.
IMO, power consumption is more likely to dictate the "hotter" card . . . though its possible for one chip to use power more efiicently than another . . . so power consumption could be misleading . . . up to a point.
I'd suggest reading qualified reviews - like here and Anand's site among a few others - and pay attention to what these reviewers indicate about the hotter - or cooler - card, and whether the difference is enough to think about.
m
l
Anonymous
a b U Graphics card
November 22, 2010 10:19:06 AM
The op is right Tom's Hardware charts can be really helpful in there you can see the same GPU from different manufactures they have different temperatures so if you go the manufactures web site you see the cards using different cooling systems and that must be looked out also. 3d power draw must be looked out and this is an issue that really counts on me.
Finally I’ve chosen HD5770 for these reasons later on I discovered there is no 3d party cooling system for this cards tested at this time, new GPU and the problem is if you don't check the 3d noise also in charts you may end up playing some demanding games with head phones over your head until something new and effective comes out.
m
l
