Archived from groups: comp.sys.laptops (More info?)
My wife spilled half a glass of water on the laptop toshiba 7020ct.
she cleaned it up.
after this incident the keys are typing the wrong letters for eg. if i
type H i get G and some times two or more letters for the same key.
She says she has pressed the keys vigorously during the cleaning i was
wondering if she activated some key or compressed some key which is
causing the problem.
i cleaned the keys by removing the keys but it did not help
I noticed some thing else when i switch on the computer it gives me a
message saying update EC / KBC . Where can i find this and how do i
update
I can use external keyboard and mouse with out any problem.
You need to let it dry for a LONG time -- days -- before attempting to
evaluate the problem. Unfortunately, the most likely outcome is that
you will have to replace the keyboard, but there is a chance that it
will be ok (the fact that it was only water is very good and helps a lot).
I'd ignore the KBC message for now, it's probably an "artifact" of the
spill problem and probably doesn't indicate a separate problem. (KBC =
keyboard controller chip, a microprocessor on the motherboard).
> she cleaned it up.
> update
> I am a computer illiterate please help
> thanks in advance
> Manohar
> email address
> manymanu@yahoo.ca
> she cleaned it up.
> update
> thanks in advance
> Manohar
> email address
> manymanu@yahoo.ca
On Mon, 07 Mar 2005 06:30:47 -0600, RedpIll <RedpIll@takeIT.org>
wrote:
>> she cleaned it up.
>> update
>> thanks in advance
>> Manohar
>> email address
>> manymanu@yahoo.ca
>get another wife.
Even if you were Mormon, there are some legal issues with that.
Besides, wife #1 might object.
