Hi,
Not a 'pro' by any means, but I've built several Digital Audio machines but this is my first with Sandybridge. And will be my first with Win7.
I need a machine that will still allow for std. PCI cards. I really have no need for high end graphics, and in fact, the fewer fans the better. All I need is dual-head VGA. I'd -love- to be able to incorporate even a small SSD for quicker boot times.
So far my tentative shopping list:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115071
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.587913
Approximate Purchase Date: 01/20/11
Budget Range: prox. $1,000
System Usage from Most to Least Important: DAW running Cubase 5
Parts Not Required: monitor, speakers, OS
Preferred Website(s) for Parts: newegg.com
Country of Origin: USA
Parts Preferences: by brand or type Intel 2600. Gigabyte
Overclocking: Maybe
SLI or Crossfire: (No idea what this is.)
Monitor Resolution: (1280x1024 x 2)
Additional Comments: (I would like a quiet PC). I need at least -3- HDs. 2 need to be 1TB, the 3rd can be an SSD. The two data drives don't need to be super fast--7200RPM is fine.
QUESTIONS:
1. In the past, the CPU came with a built-in fan. It appears the 2600 does not. Is that true? If so, I need a CPU fan recommendation.
2. In the past I simply bought Antec full size cases. Is there any reason to do so, or is a mid-tower OK. The goal is -quiet- so I'm assuming I want more air to circulate.
Can you help with a detailed parts list recommendation?
THANKS!
---JC
Overclocking: Maybe
QUESTIONS:
THANKS!
---JC
