Hello,
I am building a new system TOMORROW so I need some quick advice on whether or not the parts I have chosen are any good.
I am looking to building a gaming PC for less than $1000:
Intel Core i5-2500K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072&cm_re=copre_i5_2500k-_-19-115-072-_-Product
ASUS P8P67 PRO
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131682&cm_re=asus_p8p67_pro-_-13-131-682-_-Product
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231440&cm_re=g_skill_ripjaws_x-_-20-231-440-_-Product
ZOTAC GTX 460 768MB (I have another one in my current rig so I'll just take that one and run both 460s in SLI)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814500173&cm_re=zotac_gtx_460-_-14-500-173-_-Product
2x WD Caviar Black 500GB Hard Drive (RAID 0)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136795
OCZ ModXStream Pro 700W PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341018&Tpk=ocz%20modxstreampro%20700w
Cooler Master Hyper N520 CPU Cooler
All I need now is a case and OS (Do I really need Windows 7 Ultimate or is Home Premium good enough?). I want the total price to be below $1000, so can anyone suggest any improvements to the current components I have selected and also suggest a case that is inexpensive but has good cable management and a side windows? Thanks! I will be picking up the parts from my local retailer so please don't suggest any "combos" on Newegg.
Intel Core i5-2500K
ASUS P8P67 PRO
