Ok so this is what happened to me recently. Friend gave me a computer and here are the specs:
Dell XPS Studio 435MT 1.1.1 Motherboard
Intel Core i7 920 2.8 ghz quad core
6gb ddr3 1066mhz
radeon 3600 series 256mb ddr2 (changed from my old msi hawk r5770 1gb ddr5, too big for case)
MK Black Series 750 Watt PSU (changes yesterday from 360 Watt stock garbage)
16x dvd burner
Dell 1.1.4 Bios American Megatrends AMI
So the problem started when I was playing EQ2 on the old power supply, I didn't know it was that crappy and low, and the computer restarted and wouldn't come back on. I then checked into it more and saw the power supply was real low so I changed it and didn't go back on it until the next day when I took it apart and bought the new 750 watt power supply. Put it back together and took out my msi hawk r5770 1gb gddr5 video card cause it was big for this smaller dell case barely any room under it for ventilation. I put in an older radeon 3600 series card for now, since it was small. So now it seems if I play a game on here it works for a bit or just turns off right away, it gets really hot the video card. If I watch movies or play games it gets hot. So what should I do? Is it the motherboard or the video card? Should I get a new video card? If I get a new video card and it seems to get hot real fast then it's the motherboard? Help! Thanks
6gb ddr3 1066mhz
16x dvd burner
