G Guest Guest Dec 24, 2011 #1 Hello, Can I use a standard ATX power supply on my micro-ATX motherboard?
HostileDonut Splendid Aug 29, 2010 4,076 0 23,160 Dec 24, 2011 #2 Yes you can. It should work just fine. I have done it in the past. Upvote 0 Downvote
nukemaster Titan Nov 23, 2004 19,626 6 74,965 Dec 24, 2011 #3 What he said /\ ATX, MATX, EATX, MINIITX(a few itx boards have there own power supply) all have the same plugs and can use the Standard ATX power supply. Upvote 0 Downvote
