Hi all.
I'd really appreciate some help and suggestions on my problem.
My problem is as follows:
My grandparents have a basic computer that they use the internet, email etc. The system that they had was:
Motherboard: Intel Gigabyte GA-G31M-S2L
Hard Drive: Segate 250GB
RAM: 2 GB (Old - not DDRII)
Dvd burner: LG (not sure of the model number etc)
When I turn on the computer, it will power on for approximately 5-10 seconds and then turn off. I dont see anything on the screen. It's like the computer attempts to boot but then shuts down.
After looking through this forum and speaking to two different computer technicians, I believed that the problem was either the power supply or the motherboard.
As we dont have spare sparts to test, I advised them to take it in to find out the exact problem before proceeding. They didnt accept my advise and wanted to risk buying a new power supply.
Anyway, they go and buy a new power supply. Although it's a brand new power supply, the problem persisted. It is the same problem.
I called up the technician and he said it is probably the motherboard.
My grandparents bought the following:
Motherboard: Intel GA-G41MT-D3P (new Intel fan to put on top)
RAM: 2 GB The technician advised that we had to buy new ram because the new motherboard required DDRII ram and we had the old type of ram.
I installed the components and attempted to turn on the computer........ The same problem. The computer would power on for 5-10 seconds and then power off.
I had already attempted to change the power cable with an old one I had, but the problem persisted. I tried a completely different power socket (in case it was the socket) but same problem.
I tried to start the computer with the disk drive disconnected from the power and motherboard but encountered the same problem.
I have no idea what the problem could be. As the computer has a new motherboard, ram and power supply; the only things that are left are the DVD burner (which i assume couldn't/wouldn't cause the problem) and the hard-drive.
Does anyone have an idea of what the problem could be or what I can try to do to fix the issue. I know dont even know if the motherboard and/or power supply was the problem in the first place!
Thank you in advance for your help. It is greatly appreciated.
Regards
Martin
Regards
Martin
