S-Cable hook up problem
Forum Laptops & Notebooks : General Laptops & Notebooks - S-Cable hook up problem
Archived from groups: comp.sys.laptops (More info?)
I have two laptops that I am trying to hook up to my tv through the s-cable.
The problem that I am having is that I am not getting any color on the tv.
I have tried both my laptops (emachine 6807 and Compac 2701t) and both have
no color to the
screen. The picture is clear and very veiwable minus the color. I do have
the tv on the correct channel. So, I know that's not the problem.
Any ideas please let me know,
Thanks,
Sponsored Links
> s-cable. The problem that I am having is that I am not getting any
> color on the tv. I have tried both my laptops (emachine 6807 and
> Compac 2701t) and both have no color to the
> have the tv on the correct channel. So, I know that's not the problem.
Make sure you have it set for 16BIT color, not 24BIT or 32BIT.
Regards,
James
Reply to Anonymous
I tried it, but didn't work. Got anything else?
"JHEM" <James@ESAD.SPAMMERS.thinkpads.com> wrote in message
news:3KZWd.45421$f%5.35336@trndny03...
> Regards,
> James
Reply to Anonymous
>> problem. Any ideas please let me know,
> Regards,
> James
It is probably either the TV setup for the video input is not right or
the cable is not right. The thin s-video cables commonly supplied with
low-cost DVD players are often too high impedance for a low output power
signal and color disappears or there is no video at all when using the
cable on different equipment. Try a different cable or invest in a
higher-quality cable. Otherwise, is the video input on the TV correctly
selected and set up properly?
Q
Reply to Anonymous
"Whorrorfan" <soulless@cox.net> wrote in
news:T9YWd.27156$Im.17670@okepread01:
> both have
> no color to the
that's usually the sign of a bad cable; try another one.
Reply to Anonymous
If everything else is working and the picture is clear with just the color
missing, try a new cable.
Regards,
James
Reply to Anonymous
An S-Video cable is simply two coax cables in the same jacket, with a
4-pin connector (shield and ground for each of the two coax cables), and
a ground shell as well.
One coax carries the luminance signal (Black and white picture), the
other carries the chroma (color information).
Your situation suggests either a bad cable or a bad connector, and if
it's a connector, most likely the socket on the TV set. Visually
inspect the cable and make sure that all 4 pins are present at both
ends, they are quite thin and it's very possible for one to get broken
or bent.
> no color to the
> Thanks,
Reply to Anonymous
Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > S-Cable hook up problem
There are 1268 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
