I am building a 2500k computer with the msi p67a gd55 and the asus direct cu 6870. I am building it in one of those old white cases, which has only one 80mm fan slot (intake). I will install a fan here with a dust cover. I will use the mugen 2 cpu cooler. My psu is the antec tp 650 and will use it for exhaust (top Mount.) is that enough cooling? Other options are:
install pci brackets with holes in
memory cooling
chipset cooling
hdd cooling
mount a fan in 2 5.25 bays
drill hole in back of case for exhaust fan (last resort)
i want to reach 4.5ghz
memory cooling
chipset cooling
hdd cooling
