Solved
New Water Cooling Setup
Hey guys i was just water cooling my setup i have:
Current System:
GPU: 2 x GTX 480
CPU: Core i7 2600k
Case: Corsair 800d
power supply: corsair 1000 watt modular
motherboard:MSI P67A-GD65
Hard drive: OCZ vertex 2
Memory: Patriot Viper Xtreme Series, Division 2 Edition
I am going to water cool this system and have never don this before so i am going to order these parts please let me know if the look okay.
Water cooling equipment:
radiator:
Black Ice GTX480
http://www.dangerden.com/store/black-ice-gtx480.html#tabs
pump:
DD12V-D5 Pump Variable Speed
http://www.dangerden.com/store/dd12v-d5_pump-variable-speed-by-laing.html
tubing:
Tygon 3603 Tubing
http://www.dangerden.com/store/tygon-3603-tubing.html
CPU block:
MPC-CPU Block for LGA 1155, 1156 i3, i5, i7
http://www.dangerden.com/store/mpc-cpu-block-for-lga-1156-i3-i5-i7.html
Reservoir:
XSPC Dual 5.25" Bay Split Reservoirs
http://www.dangerden.com/store/xspc-dual-5.25-bay-split-reservoirs-w-blue-led-light-clear-silver-black.html
GPU block:
DD-GTX480 Black Chrome Top and Nickel Base
http://www.dangerden.com/store/dd-gtx480-black-chrome-top-and-nickel-base.html
I would just buy some fans to throw on the radaitor and some clamps for the tubing but do i need anything else? or do i need to change anything and what fittings do i need? Thanks for the help
4 answers Last reply Best Answer
More about water cooling setup
  1. Best answer
    No, I don't recommend going all out on your 1st h20 cooler. FYI, LGA1156 is exact same as LGA1155. So any LGA1156 cpu block will fit LGA1155. I recommend you try out a good kit of some sort. Like this:
    http://www.frozencpu.com/products/11743/ex-wat-159/XSPC_Rasa_750_RS240_Universal_CPU_Water_Cooling_Kit_Hot_Item.html
    If you insist on DIY, you need one more thing: coolant. Most use distilled water from supermarket. I'd use a nonconductive coolant. It's a bit more expensive, but it is cheap insurance for your rig if your cooler leaks. The 1st thing to go would be the gpu.
    http://www.dangerden.com/store/non-conductive-formulas/
    All the fittings must match. In your case, 1/2" ID or 3/4" OD. And your loop should be:
    pump > gpu > cpu > rad > res > pump
    out > in
    After assembly, you should test run it outside of the pc by jump-starting a psu for a few hours. 24 would be best. Fix any leaks & re-test.
    http://forum.overclock3d.net/index.php?showtopic=394
  2. Best answer selected by Wc Aftermath.
  3. Thank you for your help
  4. You're welcome.
New Build Water Cooling CPUs Systems
