Hi folks!
So I built myself a budget/entry level system about a year ago and I'm feeling like it's about time for a good bump in performance. As the build stands now:
AM3 Athlon II X2 240 2.8 Ghz
2X1GB GSkill DDR3 1333 9-9-9-24
MSI NF750-g55 Motherboard w/integrated nVidia graphics
450W PSU that came with the case
I'd like to move to 4GB of RAM and, more importantly, I need to get a better PSU in the system (to be fair it has treated me well so far, but I wouldn't want to throw anything more at it). So...
Question 1: How big a PSU do I need to feed a Phenom II X4 BE (haven't decided between 955 or 965), for now 1 GTX 460 1GB with every intention of going SLI in about 6 months, 4GB of RAM, and maybe a modest raid array? I'm not sure how much impact this will have but it seems worth mentioning that my case has the PSU mounted at the top and it seems like most of the PSUs I see have nice big fans mounted in the top of them.
Question 2: I'm think at this point I'd be better off to shelf the current 1GB sticks and go with a pair of 2GB sticks that are pretty OC-friendly. My current understanding is that my performance might not be as good if I were to simply get a second set of of 1GB sticks and run all 4 channels as opposed to running a pair of 2GBs in dual channel. Is this assessment correct or no? Does anyone have any recommendations for a reliable, OC-friendly, dual-channel 4GB kit if I am correct? If I happen to be wrong what recommendations might you have?
I do plan on overclocking and adding a second video card some time down the road. Intended use is gaming and a little movie watching. I also live in the U.S. just in case anyone would need to know those things for a recommendation or whatever.
I think that covers it so if anyone has any recommendations or general advice I'd greatly appreciate it.
Thanks.
P.S. Doing a little reading around here seems to suggest that DDR3 1333 is somewhat of a "sweet spot" in terms of reliability and performance. Is that correct? Also, what is the difference, if any, between PC3 10600, 10660, and 10666?
Thanks again.
Thanks.
Thanks again.
