I have this motherboard http://www.newegg.com/Product/Product.aspx?Item=N82E16813188039
Before I installed more ram, I didn't have any blue screen or computer crash with these 6gb triple channel ram
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227366
I wanted to buy the same ram, but ocz ram is gone now
After I installed 4gb dual channel ram, I started to have blue screen and comptuer crash
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231439
Do I have any specific way to put the one set of triple channel ram and one set of dual channel ram on this motherboard together? - I mean the order to put the rams into the slots of this motherboard
When I bought the dual channel ram set, I also tried to match the Cas Latency, Voltage and Timing as the same as the triple channel ram set.
Can someone give me the advice to solve this problem? thanks!
