Hello all,
Two months ago I built my 3rd gamming machine and now I am ready to add more RAM, cooling devices, and another GPU. My new build is as follows:
AMD Phenom II X6 1090T Black Edition Thuban 3.2GHz
ASUS M4A89TD PRO/USB3 AM3 AMD 890FX
ASUS Radeon HD 6950 2GB
CORSAIR CWCH50-1 High Performance CPU Cooler
CORSAIR HX Series CMPSU-850HX 750W
CORSAIR DOMINATOR 4GB DDR3 1600
LITE-ON Black 24X DVD+R 8X DVD+RW 12X DVD+R x2
Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM 64MB
NZXT Phantom Black Steel
Windows 7 64 Ultimate
I'm planning on getting another ASUS Radeon HD 6950 2GB * http://www.newegg.com/Product/Product.aspx?Item=N82E16814121416 * or may just swap out the 6950s and purchase two 6970's instead with two Sapphire Radeons HD 6970 2 GB * http://www.newegg.com/Product/Product.aspx?Item=N82E16814102918 *. Either way I will be Crossfiring this system really soon. Also I will had another set of CORSAIR DOMINATOR 4GB DDR3 1600 * http://www.newegg.com/Product/Product.aspx?Item=N82E16820145290 * along with some GPU cooling options such as ZALMAN VF3000N Enter VGA Cooler * http://www.newegg.com/Product/Product.aspx?Item=N82E16835118064 *. I'm still not sure which route to go with since the NZXT Phantom has a water cooler holes pre prep for this case, but my main concern is will my current 750W is able to handle the extra hardware I plan to add?
