IBM TP600X LCD/CRT problem
Forum Laptops & Notebooks : General Laptops & Notebooks - IBM TP600X LCD/CRT problem
Archived from groups: comp.sys.laptops (More info?)
Hi, my TP600X has a weird problem with the display going blank
occasionally. If I press the Fn+F7 several times to change the display
mode, then the picture comes back. It may work for hours or some minutes
before the effect reappears.
What could be the problem? I'm using Windows 2000 and SP4.
I tried to look for clues in Google newsgroups from ibm.ibmpc.thinkpad
etc. and some similar symptoms exist but no resolution. Some suggest a
problem with the lid switch, some the motherboard.
Thank in advance,
Jussi
Sponsored Links
> Thank in advance,
> Jussi
When the display shuts off, hit the lid switch and see if it comes back. Next
time it gos out, move/flex the lid, see if it comes back.
Hi Tommy, come on up here, have you ever been up in the cockpit before?
Captain Ovuer - Airplane
Reply to Anonymous
>>Thank in advance,
>>Jussi
Capt.,
That is affirmative! The problem seems to be the switch indeed, as when
I touch it the screen comes back & vice versa.
Now is there a cost effective way to clean / replace the microswitch
(like FRU2645-XXXX or a Radio Shack switch) ? Or should I just bypass it
on the circuit board? Bypassing would mean no standby mode.
Thanks, you saved my day!
Jussi
Reply to Anonymous
>>> display mode, then the picture comes back. It may work for hours or
>>> some minutes before the effect reappears.
>>> ibm.ibmpc.thinkpad etc. and some similar symptoms exist but no
>>> resolution. Some suggest a problem with the lid switch, some the
>>> motherboard. Thank in advance,
>>> Jussi
>> back. Next time it gos out, move/flex the lid, see if it comes back.
> Capt.,
> when I touch it the screen comes back & vice versa.
> it on the circuit board? Bypassing would mean no standby mode.
> Jussi
You might clean the switch with electronics cleaner. BTW the laptop
should go into standby just fine even if the switch is bypassed; the
switch simply triggers standby on lid closure.
Q
Reply to Anonymous
Not a good idea. It also turns the display off when closed.
Regards,
James
Reply to Anonymous
Take the keyboard surround off and clean the switch with canned air and
_gently_ clean the plastic pushrod that activates it.
Rarely necessary to replace or bypass the switch.
Regards,
James
Reply to Anonymous
Is the switch sticking? You may try to clean it.. try a can of compressed air
to blow dust out from contacts, but be careful, the switch is fragile, so try
not to rock it while cleaning. you could bypass it, but the screen would stay
on..
> >>Thank in advance,
> >>Jussi
> Capt.,
> Jussi
I am BillGatus of Borg. Resistance is futile. You will be assim
[General Protection Fault]
Reply to Anonymous
I had that problem with mine, it turned out to be the backlight.
Although replacement backlights are sold for about $60.00, the
problem was finding a place to do the replacement, most places won't
open up the display to repair anything, they'll try to rip you off
and make you buy an entirely new display system for like $300.00.
I did manage to find a place, the guy replaced the backlight, labour
included it only cost me $80.00.
Reply to Anonymous
still kinda pricey when backlights run $25. I hope $55 labor included dinner
and a movie.
Reply to Anonymous
Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > IBM TP600X LCD/CRT problem
There are 1150 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
