Problem running NFS the run
Last response: in Windows 7
November 23, 2011 7:59:25 AM
Hello,
I have Win 7 Home premium (2,9Ghz 64bit) After succesful installation trying to start the game an error occurs saying the file therrun.exe is not a legal 32 bit application !? Win SP1 and DirectX 11 also installed
May 3, 2012 7:11:31 AM
the best solution to any game problem is that
You install/re-install the following softwares:
.Net Framework
VC++ (x86/64)
Direct X
MSXML
your problems will be solved
remember to restart when u install the above
