Problem with Powercolor Hd 6850:100mhz, memory 300,no shader
Hello,
I bought a new system with a Powercolor HD 6850, I am having problem with the gpu.
My spec
Asus p7p55d-E LX
i5 760
ocz 2gb RAM (i stick is defect)
Powercolor HD 6850
WD 1T black caviar
ocz 600w psu
I have installed
catalyst 10.10.
Driver Packaging Version 8.782-100930m-106343C
Direct x installed
Win XP 32
Here the problem:
- The video cards in CPU-Z is detect as a core: 100mhz, memory 300mhz, no shader
- Performance Test : cant run 3d test since I have reduced rendering-capabilities
- 3dmark06 : cant open the program, i have no idirect3d9.
- Eve online : would not even open
- Screen is flickering in explorer when i scroll.
I had problem with the installation at first, no image but I removed the driver and software, cclear and driver sweep, reboot, reinstall.
It is a defect card ? Anythings I can do ?
Thank
2 answers Last reply
More about problem powercolor 6850 100mhz memory shader
  1. I think this is driver issue...
    Download the latest driver (10.11) from AMD site and install it, make sure you get rid (uninstall) the old (10.10) one...
    If the problem remains then RMA the card, you might get a defective card.
  2. grunts67 said:
    Hello,
    My spec
    Asus p7p55d-E LX
    i5 760
    Powercolor HD 6850
    WD 1T black caviar
    ocz 600w psu
    I have installed
    catalyst 10.10.
    Direct x installed
    Win XP 32
    Here the problem:
    Thank
    Hello the problem is you need the hot fix, there is no full support for our cards yet and you need to use the hot fix (Note the link below supports Windows XP 32-Bit)
    AMD Catalyst™ 10.10b Hotfix: Windows XP® Support for AMD Radeon™ HD 6870 and AMD Radeon HD 6850 Graphics Products
    (Note! AMD Catalyst™ 10.11 does not provide support for the AMD Radeon™ HD 68xx series of graphics cards. Full support for these graphics cards is targeted to be available in the AMD Catalyst 10.12 driver release)
    Last Updated
    10/22/2010
    Article Number
    GPU-85
    AMD Catalyst 10.10b Hotfix Features:
    * Support for AMD Radeon HD 6870 and AMD Radeon HD 6850 series graphics product installed in a Windows XP based system
    Instructions:
    Download and install the AMD Catalyst hotfix from the following location:
    * AMD Catalyst 10.0b Hotfix for Windows XP Professional Editions
    Refer to Article 20870 for detailed instructions on how to properly install the AMD Catalyst hotfix.
    Note! This hotfix is provided as is and is not supported by AMD. It has not completed full AMD testing and is only a driver update.
Graphics Cards PowerColor HD Graphics
