Help me with a build
Last response: in Systems
Hello,
I am looking to build my first computer.
Budget: $800-$1,000
Used For: Gaming, watching HD movies and surfing the internet.
All parts will be bought from CompUSA locally.
I do not require Monitor, everything else I need.
I like the Cooler Master HAF 932 Case.
Thank you for your help in advance.
So far I have:
Case
CPU
DVD-R/W
Mobo -- Not sure if this mother board runs i5
Budget: $800-$1,000
So far I have:
Case
CPU
DVD-R/W
More about : build
Why CompUSA? Why not just buy from Newegg? You'd save a lot of money and get better selection.
Here's what I'd build (using Newegg prices):
CPU: i5-2500K $225
Mobo: ASRock P67 Extreme4 $156 with shipping
RAM: Corsair XMS3 2x2 GB 1600 mhz CAS Latency 9 $40 after rebate
HDD: Samsung Spinpoint F3 1 TB $60
GPU: GTX 460 1 GB $170 after rebate or HD 6950 $260 after rebate
PSU: XFX 650W $74 after rebate and shipping (with the GTX 460) or Antec Earthwatts 750W $80 (with the HD 6950)
Case: HAF 922 $100. Very similar to the 932, but a much better value
Optical: Cheapest SATA DVD burner $16
HSF: Scythe Mugen 2 Rev. B $43 with shipping
Total: $884 w/ GTX 460 or $980 with HD 6950. That's after rebates and shipping. Also wasn't sure if you needed a copy of Windows (here's a combo with the F3 or not. If you need more room in the budget than what you get with the 6950, you could drop to the HD 6870 or HD 6850.
Also, the 6950 has the interesting feature that if you flash the BIOS to that of a 6970, it will run like one. That's a huge free performance boost.
CPU: i5-2500K $225
MadAdmiral said:
Why CompUSA? Why not just buy from Newegg? You'd save a lot of money and get better selection.Here's what I'd build (using Newegg prices):
CPU: i5-2500K $225
Mobo: ASRock P67 Extreme4 $153
Total: $881 w/ GTX 460 or $977 with HD 6950
Could you do it on CompUSA website? I am in Deerfield beach FL.
Related ressources
- New build around 1000, help me out? - Forum
- Help me finish my build please! - Forum
- Looking to build budget gaming PC Please help me !! - Forum
- Help me pick the perfect Graphic Card for my Monitor and Build - Forum
- Help me build my first gaming pc. - Forum
MadAdmiral said:
I'm not doing it on CompUSA's website, but feel free to try it out.The i5-2500K destroys the X6s. It's even faster than the $1,000 i7-980X in some applications. I wouldn't touch an AMD build right now. They're just too weak.
http://www.compusa.com/applications/SearchTools/item-de... - does that seem right?
Would this mother board work for the i5-2500K http://www.compusa.com/applications/SearchTools/item-de...
OR http://www.compusa.com/applications/SearchTools/item-de...
That's the CPU.
That board will work, but the second PCIe 2.0 slot (the one for the video card) only runs at 4x. That makes it useless for Crossfire/SLI (dual video cards). The Pro version has the slots running at 8x, which is useful. It is more expensive though.
I wouldn't touch a $300 board. Besides, that's not compatible. It's an LGA1366 socket board, and the CPU is an LGA1155 socket.
You can't find either the Asus P8P67 Pro or Gigabyte GA-P67A-UD4 locally? I'd probably just wait until it's in stock. Or settle on the MSI P67A-GD65. I can't find if the second PCIe 2.0 slot runs at 8x or not, but there's a very similar one (the GD63) for $40 less. That's generally what the price difference is between a board with a 4x slot and one with an 8x slot.
Also, the speed of the second PCIe 2.0 slot doesn't make them bad boards. It just means you won't be able to Crossfire/SLI later. The P8P67 and UD3 are both great boards, as long as you understand what you're buying. If you have no interest in adding the second video card down the line, then it makes no difference to you. If that's the case, you could also drop the PSU down a notch or two. A 450W would be enough for a single GTX 460 and a 550W would be able to handle the other cards just fine.
Actually, no you didn't. That's a LGA1155 board, but it's a really bad one. Intel's motherboards are pretty much the bottom of the barrel in terms of quality. I wouldn't touch it.
Given your TV/monitor's resolution, any of the other boards you linked to would be fine. The only "problem" with them relates to trying to run two video cards at the same time, where they would be extremely handicapped. However, given the low resolution you'll be playing at, you don't need a second GPU. If you were to step up to a 1920x1080 (1080p) TV/monitor, you'd still be alright with a single GTX 460. You'd get amazing performance with the 6950. Unless you were trying to game on multiple montiors at the same time, you'll be just fine.
Knowing what you've got for a monitor, I'd acutally recommend getting the GTX 460 (the $900ish build). You can leave out the HSF for now, which would allow you to afford a 21"-23" 1920x1080 monitor. You'd still get great performance from pretty much every game out there (you'd have no issues with MW or SC2 whatsoever).
Best solution
Related ressources:
- ForumHow to Ask for New Build Advice
- ForumTroubleshooting
- More resources
on their site.
