2nd build, i5 system
Last response: in Systems
January 26, 2011 6:33:12 PM
hi Guys,
mind checking out my final build list for any problems or advice? Any changed I need to make etc etc.Thanks a lot! I'll be playing on a 24 inch 1920x1080 monitor fyi. my budget is around 1600.
2x SAPPHIRE 100314-2SR Radeon HD 6870 1GB
ASUS P8P67 PRO LGA 1155 Intel P67
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
COOLER MASTER RC-692-KKN2 CM690 II Advanced Black Steel ATX Mid Tower Computer Case
CORSAIR HX Series CMPSU-750HX 750W ATX12V 2.3 / EPS12V 2.91
Intel Core i5-2500K Sandy Bridge 3.3GHz
Corsair Nova Series CSSD-V64GB2-BRKT 2.5" 64GB SATA II MLC Internal Solid State Drive (SSD)
CORSAIR CWCH50-1 High Performance CPU Cooler
More about : 2nd build system
January 26, 2011 8:37:45 PM
Looks great! I am presuming that you are going to use a HDD as storage device along with the SSD for OS.
January 26, 2011 9:11:31 PM
decent enough. don't forget a mechanical drive for storage samsung spinpoint f3 1 TB or F4 2 TB will be great
January 27, 2011 1:27:52 AM
My personal choice would be to spend a little less on a cooler (ex: Hyper 212 Plus) and get a better ventilated case like Antec 902 that would also help keep all other parts cooler. If you plan on using 2 of those 6870, you might also want to consider getting the XFX Black Edition, it's OCed, but also very silent (the later being the interesting point). I know it's going to cost more, but I don't like noise so I though I should say.
