Solved
Building New System - All Compatible?
Hi I am building a new computer system and wanted to double check with anyone if all of these components are compatible with one another.
If you have any suggestions or changes with this build please let me know. And I am still unsure if I have enough to keep this system cool enough.
A little out of order but here it is:
Quote:
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
COOLER MASTER HAF X RC-942-KKN1 Black Steel/ Plastic ATX Full Tower Computer Case
Western Digital Caviar Blue WD6400AAKS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
EVGA 012-P3-1472-AR GeForce GTX 470 (Fermi) SuperClocked 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support ...
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power ...
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-4GBPQ
ASUS Sabertooth X58 LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Intel Core i7-950 Bloomfield 3.06GHz LGA 1366 130W Quad-Core Processor BX80601950
COOLER MASTER V8 RR-UV8-XBU1-GP 120mm Rifle CPU Cooler Intel Core i7 compatible
Thankyou!
6 answers Last reply Best Answer
More about building system compatible
  1. You have listed DDR2 ram! You will need DDR3 ram I suggest a triple channel kit like this one http://www.newegg.com/Product/Product.aspx?Item=N82E16820231304
    If the build is for gaming I suggest looking at LGA1155 instead, it wins over LGA1366.
  2. Thanks for the replys!!
    So you guys think I should swap out the i7 I chose with the i7 2600K?? Or switch to the i5?
    And I also am going to purchase the V8 Cooler for my processor but I am a little bit worried its massive size wont fit in my case, you guys know anything about the size vs the case?
  3. Best answer
    The V8 should fit that case easy. I5 2500K is they sweet spot for gaming and wins over the I7 2600K in some gaming benchmarks. Pair it up with a P67 board and a dual channel memory kit and you have a very fast system.
  4. Thankyou! I just swapped out some parts for the following:
    Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
    ASUS SABERTOOTH P67 LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
    The parts are ordered and if all successful, think i'll start offering a helping hand to these forums and become an active user - I've been browsing toms for years now never have signed up lol
  5. Best answer selected by mattg2.
New Build Compatibility Systems Product
