Hi All,
I have a dual-CPU setup (KGPR-D16 MB, 2x AMD 6129 8 Cores). I have Thermaltake CLS0017 CPU coolers.
The tower I'm using is an ANTEC P193. Lots of fans, all of them running on lowest setting. I use the onboard video, the HD is in the lower cavity along with the power supply so I believe the air flow is rather good. I have three outtake fans (effectively surrounding the CPUs) and the intake is a massive fan on the side of the case. I keep everything rather clean and free of dust.
I use the system exclusively for scientific computing and I basically have all 16 cores working at 100% 24/7.
Here's the issue:
When I'm running the system at 100% capacity, I find the CPUs are at distinctly different temperatures. CPU0 (closest to the rear panel) hits around 65 degC, with the CPU fan having to rev-up constantly to maintain that temperature. CPU1 on the other hand is fairly cool at a mere 44 degC with the CPU fan never going above its lowest setting.
If I turn all fans to maximum (and make my office sound like an airport) I don't really see any difference in CPU0 temperature.
I really rely on this system for some time sensitive work (finishing my thesis), so I'm hesitant in both to fix or disturb things. I don't want my CPU0 to take down the system at some point, but I also don't want my system down for any period of time as I fix things.
(1) I was thinking about taking CPU0 out of its socket and checking the thermal paste (maybe the contact is poor).
(2) I was also thinking it might be a problem with the CPU itself (some defect).
(3) Maybe the placement of the fans or the location of the CPU on the motherboard is non-ideal.
(4) The CPU cooler being sub-par (anyone else have experience with this?)
I'm wondering what I should look for if I try to replace the thermal paste, how to remove the stuff and re-apply? Also, if the re-application of thermal paste doesn't solve the problem, where can I go from there?
The thing is I realize everything is okay as far as stability goes (no crashes) but it's disconcerting to see a 20 degree difference between two identical CPUs being loaded identically.
Any help and opinions would be greatly appreciate!
Here's the issue:
