Put everything in place and plugged everything in, turned on my computer for the first time with little happening. The fans all turned on the green LED indicating it got power turned on. The DRAM_LED/MemOK was blinking red. (No beeping).
When I took the memory out the speaker beeped once long and twice short indicating there was no memory. When I replace the ram and power on again the above happens but nothing else.
The ram isn't listed as one being compatible in the manual although I don't know why mine would be incompatible. I believe the issue is the ram because if I take out the monitor the speaker doesn't beep idicating no monitor. According the manual the blinking red indicates the mobo is testing the ram but I let it run for 20 mins with nothing changing. I also tried doing the same with only one stick of RAM but that didn't seem to do anything differenetly. The manual also claims that if the light turns solid red it means the ram is incompatible, which has not happened (only blinking). Any suggestions or comments are appreciated. Thanks.
MOBO: http://ncix.com/products/?sku=51007&vpn=M4A89GTD%20PRO%2FUSB3&manufacture=ASUS
RAM: http://ncix.com/products/?sku=44264&vpn=F3%2D10666CL9D%2D8GBRL&manufacture=G%2ESkill
