First rig, need help
Last response: in Systems
I plan on using this setup for games/movies/music and all around multipurpose use. I'd like the build to be overclock friendly across the board with the possibility of SLI in the future.
Tower : NZXT Phantom PHAN-001WT White Steel / Plastic ATX Full Tower Computer Case
Solidstate Harddrive Don't plan on buying one at the moment but wouldn't mind a suggestion
Harddrive : SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Monitor : ASUS VH236H Black 23" 2ms(GTG) HDMI Widescreen Full HD 1080p LCD Monitor
PSU : CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
(could use help here, I only went off price/review ratings to choose this one, would like to eventually overclock and possibly SLI)
RAM : G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
OS : Microsoft Windows 7 Professional 64-bit 1-Pack for System Builders -OEM
CPU : Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
Videocard : MSI N560GTX-TI Twin Frozr II/OC GeForce GTX 560 Ti (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
(not sure which version of the GTX 560 Ti is best so I will be using the cpu's integrated graphics until more reviews/ratings come out for gtx 560's)
Motherboard : ASUS P8P67 PRO LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Soundcard : ASUS Xonar Essence STX Virtual 7.1 Channels PCI Express x1 Interface 124 dB SNR / Headphone AMP
(this will be purchased at a later date along with a high quality headset, just want to make sure its compatible)
I've added/changed some components on a pc before but never a motherboard/cpu or assembly from scratch so if someone could post a newbie friendly guide for it I'd be grateful.
More about : rig
Related ressources
Since sandybridge has been pushed back I've decided to wait it out and slightly upgrade a few components, mainly the PSU with the SLI of 2 GTX560 TI being alot more likely then before. Question is will a 750w psu be enough to run that setup comfortably with room for future additions and even being moved to newer more powerful builds, or should I be looking at a 850w.
http://www.extreme.outervision.com/PSUEngine
I used this site to try and give me a reference but not sure how accurate it is. It said I needed a minimum of 630.
Ask the community
