B bubbaj1234 Distinguished Apr 25, 2011 1 0 18,510 Apr 25, 2011 #1 So, i'm trying to get a multiplayer system to work on an online game thing, and it requires my cpu to be at least 450. my cpu keeps jumping from 25-860 in a matter of seconds... any suggestions on how to keep it at the minimum requirement?
G ghnader hsmithot Distinguished Oct 14, 2010 3,030 0 20,960 Apr 25, 2011 #2 450mhz??or 45ghz?rarely these days are the cpu causing problems for games.I think you should go and check your gpu. Upvote 0 Downvote
geekapproved Splendid Dec 10, 2010 8,766 0 31,460 Apr 25, 2011 #3 If your cpu isn't at least 450mhz, I would not try to play any online games. Upvote 0 Downvote
king smp Splendid Jul 16, 2010 9,623 7 31,515 Apr 25, 2011 #4 OP what are system specs? What is the 450 number you are referring to? Upvote 0 Downvote
A andruu Distinguished Apr 25, 2011 6 0 18,510 Apr 25, 2011 #5 too bad you cant give it methadone :/ Upvote 0 Downvote
king smp Splendid Jul 16, 2010 9,623 7 31,515 Apr 25, 2011 #6 No No No Methadone is for Heroin Coffee and cigarettes are for Crack! Upvote 0 Downvote
