Please help! I just built a pc but not working!!!
Last response: in Systems
Hi guys, I just finished building and turned it on.
Case light/cpu fan, probably gpu fan, and case fan were all working for 2 sec but then it all got turned off after 2 sec.
currently, power, reset, and CLR CMOS of motherboard has lights on, proving that power current is still going thru the motherboard.
what do u guys think went wrong? please help!!
More about : built working
Thank you everyone for answering my question.
Currently, I fixed the problem but couldn't find the cause of shutting off in 1 sec.
What I did after failing it twice, I disconnected ram, GPU from motherboard, motherboard from case and started to connect one by one while turning it on each time and it fixed somehow. I know it's kinda wierd, power connector wasn't problem and i am sure I connected everything correctly even for the 1st time, so...case solved yet still mystery.
Ask the community
