Solved
Any ASRock P67 Extreme4 users with advice on CPU cooler?
Hello,
I was wondering if anyone had any experience with the ASRock P67 Extreme4, and more specifically, a CPU cooler that fits well, without blocking a RAM slot, pushing against the onboard heatsink fins that surround the chipset, or any other annoying idiosyncracies. I'd love to put a Hyper 212+ or something similar there, but I'm not sure about the clearance, and whether it will fit properly. My specs as follows, and thank you in advance for your suggestions.
CPU: Intel i5-2500k
Motherboard: ASRock P67 Extreme4 ATX
Case: Cooler Master HAF 922
GPU: Palit Sonic GTX 560Ti 1GB
RAM: G.SKILL Ripjaws X Series 4GB DDR3 1600 (PC3 12800)
Power Supply: XIGMATEK 700W ATX12V v2.3 SLI/CrossFire Ready 80+ BRONZE Cert
Monitor: Sony Bravia 32" 1080p HDTV.
Thanks again,
Justin S.
7 answers Last reply Best Answer
More about asrock extreme4 users advice cooler
  1. capitalistpigskin said:
    Hello,
    CPU: Intel i5-2500k
    Thanks again,
    Justin S.
    This doesn't exactly seem to be a ringing endorsement for the ASRock P67 Extreme4 :(
  2. Best answer
    Hyper 212 will fit just fine
  3. Best answer selected by capitalistpigskin.
    Thanks for the input! On the way to grab one so I can finally put the accursed build to rest.
  5. hey did the Hyper 212+ fit without blocking any RAM slots on the ASRock P67 Extreme4?
    Hey did that Cooler Master Hyper 212+ fit on your ASRock P67 Extreme4 without blocking RAM slots?
  7. Fits beautifully. The new system kicks serious ass.
Homebuilt Cooling CPUs ASrock Systems Product
