Sound card prblem
  • Sound Cards
  • Device Manager
  • Components
Last response: in Components
April 15, 2011 5:00:36 AM
Hi,
Re-installed WinXP pro. Have no sound now, but previously sound was fine. In Device Manager it says "Legacy Audio Drivers" are fine. I have no idea what to do now.
Can someone advise, please? Thanks very much.
More about : sound card prblem
April 17, 2011 3:42:52 PM
Double click the speaker icon in the lower right hand of the desktop, this will bring up the mixer, or single click to bring up the volume control.
But in case the volume is missing, corrupted, or the audio is otherwise non-functional:
you check whichever audio was installed:
click start, control panel, add remove programs, look at the list...
which audio software is shown on the list? delete it, restart the computer.
now visit the motherboard manufacturer or computer manufacturer's website
(in this case it's the sound card manufacturer's website)
look up your computer drivers (card drivers) by model number
download the latest audio drivers, save on the desktop...
turn the antivirus off,
if you have multiple security programs installed, turn them all off
(your driver may not install if security systems are turned on)
now load your new audio driver, restart, turn the antivirus back on.
Let the forum know if that solves the problem. SGM
April 25, 2011 8:57:52 PM
This topic has been moved from the section Home Audio to section CPU & Components by CompTIA_rep
